What fan is best?
Noell21
06-21-2005, 01:25 PM
I have an '82 and an '85 Suburban. Both are 1500's with V8's and AT. Both have had some type of engine swap so I don't know what is original. The fan clutch went out on the '85 I drive every day so I swapped the fan and clutch from the '82. Question - the fan on the '85 had 5 blades with an irregular spacing and the '82 had 6 blades with more regular spacing. Which one should I keep on the '85 when I sell the '82?
Neither truck is worked real hard so I don't need maximum cooling. I wonder which fan type is the later model and why they changed. More cooling? Less noise? Space to get to the bolts?
Thanks, Noell
sub006
07-08-2005, 12:56 AM
From what you describe it's six of one, half a dozen of the other. More blades is usually more airflow. My '90 has always run so cool I usually fit the lightest-duty fan clutch I can find when I replace them (truck has almost 400,000 miles), keeping the original stock fan.
If you don't mind a bit more noise you can replace the fan clutch with an aluminum spacer and longer bolts, then install a lightweight fiberglass or aluminum flex fan. They turn all the time but feather themselves out of the airstream at higher rpms. Supposed to be good for about 15 extra hp.
