has this happened to anyone esle....ford460bigblock 06-18-2005, 05:35 PM today i drove my car for like 20 miles....then out of nowere a Grinding noise came from under the hood. its not the brakes casue it does it in park too. it almost sounds like theres sand in my engine....i asked someone about it and they said its becasue i put 93 fuel and i should be putting 87...has this happen to anyone ford460bigblock 06-18-2005, 05:44 PM oh the belt, brakes are new and theres oil ford460bigblock 06-18-2005, 09:15 PM just got back form a ride and i think it only happens when the fan goes on Mod'd_Cav 06-18-2005, 10:09 PM lol...then check the fan dude...look around the fan blade and see if anything is rubbing and scraping...it could just be something simple like the fan guard...or you could need a new rad fan altogether ford460bigblock 06-18-2005, 10:39 PM i said i think Mod'd_Cav 06-18-2005, 10:51 PM ya but you should still check...spin the fan..if it stops while your spinning it by hand then its the fan...also if the grinding speed increases with the rpm speed then the fan is out as a possibility ford460bigblock 06-18-2005, 11:41 PM the nose is consent public 06-19-2005, 08:24 AM the nose is consent the fan runs at a constanty speed. Spin it by hand feeling for a bad bearing. They can make a lot of noises similar to what you describe. Good Luck. ford460bigblock 06-20-2005, 10:56 PM the sound is coming from the alternater....could it be that the belt is to loss or to tite? rob487 06-20-2005, 11:42 PM The belt is tensioned automatically by a spring loaded belt tensioner. There's no adjustment to it. roof 06-23-2005, 10:33 AM You say its comming on with the fan, and from the alternator, perhaps its under the altenator? IE the water pump, if part of its broken off and entrained in there it could sound like sand or somthing tearing apart the blades of the impeller. I know when my pump failed the blades were gone, still in the engine, or disentegrated i dont know lol chevyguy93 06-23-2005, 02:03 PM Maybe a bad alternator? If it starts when the fan comes on, then maybe the alternator is having a hard time keeping the battery charged. Happened in my dads truck, the alternator would make weird noises when the fan kicked in. Maybe take it somewhere and get it tested. just a thought big dude1 06-24-2005, 10:40 PM if it was the water pump it would do it all the time because your water pump is ALWAYS running i would check for brokeded fan but maybe your alternator is going out? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
