'89 Cavalier Z24 likes to shudder
SirHOBO
06-16-2005, 06:31 PM
My '89 Cavalier Z24 has been shuddering when I'm driving it around 30-40mph. My plugs and wires were recently replaced last year to fix this problem, but did not work. I also replaced the EGR valve and PCV valve recently. Does anyone have some suggestions on what may be wrong?
Thank You.
OverAllComa
06-16-2005, 07:10 PM
May want to start with all filters and such. Also make sure you've cleaned out the TB, those 2.8/3.1 TB's get REALLY dirty after a few years, all black and gunked up.
From there, check the TPS (sensor on top of the TB) which would cause a shudder.
All of this could be for nothing, could you clarify if it's an "engine" shudder or a "suspension" shudder or you don't know yet.
SirHOBO
06-16-2005, 08:12 PM
It seems to be a engine shudder. I do have mostly new filters. So I suppose I should clean out the TB (Throttle Body, right?) What would be the best way to do that?
OverAllComa
06-16-2005, 09:06 PM
Just unhook all the air intake stuff and get some torx bits to take off the TB. Of course you got a sensor or two and some vacuum lines, nothing big. DO NOT forget to go to the car place and get yourself a TB gasket before doing this.
Beyond that, I just took it out and went nuts with some carb cleaner and a bunch of rags, most of my buildup was on the back side of the valve. Have fun. Even if it's not the problem, it can never hurt.
