Question on spark plugsshooterc5 06-14-2005, 11:45 PM I have a 99 gtp. Mods are 3.4 pulley, DHP pcm, U bend delete, TB spacer, and a CAI. I want to run autolite plugs but not sure if i should run 605,s or 104,s. Basically wondering if I should going two heat ranges coulder or one heat range colder at this point. Any advice would be appreciated. Thanks. kustomkid54 06-15-2005, 12:10 AM I have a 99 gtp. Mods are 3.4 pulley, DHP pcm, U bend delete, TB spacer, and a CAI. I want to run autolite plugs but not sure if i should run 605,s or 104,s. Basically wondering if I should going two heat ranges coulder or one heat range colder at this point. Any advice would be appreciated. Thanks. I wouldn't. Not with the mods you have. 605's and 104's should be fine. Good luck Ripn12s 06-15-2005, 06:59 PM 104's kustomkid54 06-15-2005, 07:45 PM 104's Hi Tim, That was short and to the point. :cheers: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
