1992 b18 into a 91 crx?
BIGDPCRX
06-12-2005, 04:47 PM
i wrecked a 92 teg and i am putting the b18 into my crx, my crx is a dx so i had to do the mpfi convesion, i got it all in and its turns over, but wont start, im pretty sure that it is the injectors that arn't workin, do i need a 92 civic si ecu instead of the 91?
charliemopps24
06-19-2005, 11:27 PM
It's either the injectors or the ignition. First check your fuses. If they're good, then move on to checking the components with a multimeter or a noid light (yeah it really is called a noid light). Always check your stuff before you just go buyin new ones.
Rgacke
06-23-2005, 02:57 AM
You need to realize that your engine is OBD1. If you are using the original injectors you do not need the injector resistor box and you said you have a 91 ecu, 91 what? If its a pm6 Si ecu thats OBD0. You ecu,injectors,dist have to match to keep things simple.
in short, use the ecu from the teg.
