check engine light- help me
Google
Web AF
anos_l
06-09-2005, 09:21 AM
I have Toyota Corolla 1998
the check engine light is on , the code is P0441
Evaporative Emission Control System Incorrect Purge Flow
please help me!
johnholl
06-09-2005, 12:23 PM
Check with your dealer and see if your emmision components are covered under warranty. Someone said 80,000 miles? Could be purge valve not openning all the way. Ive got the same code and its driving me nuts too. Valve seems to work while bench tested
anos_l
06-11-2005, 05:09 PM
please help me!
I changed purge valve but check engine light is on
anos_l
06-12-2005, 04:15 AM
pressure switcching valve is the samething with pourge valve ?
because is the pressure switccing V. I changed
bcopeland
06-12-2005, 04:45 PM
GAS CAP! Ha, Ha, Ha. Come on you experts!
anos_l
06-12-2005, 07:37 PM
I changed the gas cap but the light it still is there
johnholl
06-13-2005, 12:05 PM
Hey Berry. Do you really believe that the gas cap can set this code? If so do I have to purchase an OEM cap?
BTW, as a fellow Malibu owner, my condolences.
bcopeland
06-13-2005, 12:15 PM
yeah, thanks - I guess (on the Malibu). But usually it reads gas cap if it comes up after a while out of the blue.
johnholl
06-13-2005, 01:15 PM
Usually a faulty gas cap will trigger a "large leak detected" code. The P0441 may, or may not be triggered by a miniscule leak. I don't have the car now [getting a used transmission]. When i had the car the solenoid bench tested ok. When I get it back i will check the emmision lines running to the canister, located under the car in front of the gas tank for their condition. We have OBD II testing in this state as part of our inspections..and the system has to work, or your screwed. Isn't that nice.
Google
Web AF
