fitting quad throtlle bodies from 20valve to 16valve 4age
Google
Web AF
r100
04-17-2002, 07:23 AM
i need some information/advice on fitting 20valve 4age throttle bodies to a 16valve t-vis 4age engine. has anyone done this before? any help would be greatly appreciated. thanks.
howard_w13
04-17-2002, 11:03 AM
Originally posted by r100
i need some information/advice on fitting 20valve 4age throttle bodies to a 16valve t-vis 4age engine. has anyone done this before? any help would be greatly appreciated. thanks. :huh: :confused: :huh: :confused: :huh:
This IS for a G20 or some other SR20DE car right?:confused:
lloyd_nickens
04-17-2002, 12:48 PM
That sounds like the engine toy uses in their na mr2
Yahnozha
04-17-2002, 08:08 PM
Two words....Duct Tape...lol
Seriously, you might want to ask this on the se-r mailing list. A lot of sr20de gear heads on there. http://www.se-r-list.org/
But from the sounds of it, I dont think this applys to our engine...
P10DET
04-17-2002, 09:07 PM
TW Induction. Expect to spend at least $750 (probably more) before you're done.
howard_w13
04-18-2002, 10:34 AM
:confused: I'd love to see what you all are talking about. Anyone have any pics of this 20-valve 4age throttle body thingy?:confused:
P10Skin
04-19-2002, 11:34 PM
The 4age is a toyota engine used in sum mr2's most FX GT's, Sprinters, GT Apex's etc it is the toyota version of the sr20de (ie their mainstream engine for their cheap-mid class cars I think it is 1.6 litre and it has a pretty good power output! try a site like www.club4ag.com or www.toyspeed.org.nz they may have the info or be a better place to make a post regarding that engine! also if u have thta much money to spend why not just get a 4agz (the supercharged version of the 4age) my mate did that too his FX GT4 and it goes pretty good!
Moppie
04-25-2002, 01:32 AM
I'll just move this into the Toyota forum. :D
And,
The the ports and studs on the head are actualy quite differnt.
It can and has been done, but requires some port matching and cuting and drilling of the manifold mounting plate.
Its an easier swap onto a 4agze, then the ports match up, and only one hole in the mounting plate needs to be changed.
Your actualy better off sticking with the stock intake. The quad throttle bodies will give you very minimal gains unless your building a 250+hp race only engine. :)
jOYRiDe
06-08-2002, 10:41 AM
why not just swap the whole 20V engine over instead of swapping the quad TB?
if u do, look for a black rocker cover 20V. they have 6 speed trannies. very rare :coolguy:
but IMO i'd go with 4AGZE, throw the S/C and bolt on a turbo instead.
Google
Web AF
