Problem Starting MY 86 CAPRICESET TRIP 06-07-2005, 07:15 AM On My 86 Caprice I Have A Loose Column.it's Been Like That For A While Now, But Recently Its Been Giving Me Troubles Starting. My Battery Remains Charged, But Everytime I Try To Start At Any Time, All I Get Is A Click. I Also Noticed That For A While It Would Start If I Work The Steering Wheel A Couple Times. Sorry If My Problem Is Not Very Clear, But Can Someone Please Help??? PeteA216 06-07-2005, 05:29 PM It sounds like your starter. It needs new brushes. It probably cranked over when you moved the wheel around because doing that happened to cause just the right amount of vibration to get it going. Thats just my guess. To confirm it have someone underneith the car and tap the starter with a hammer (somewhat hard) when you try to crank it over. SET TRIP 06-11-2005, 08:01 PM It sounds like your starter. It needs new brushes. It probably cranked over when you moved the wheel around because doing that happened to cause just the right amount of vibration to get it going. Thats just my guess. To confirm it have someone underneith the car and tap the starter with a hammer (somewhat hard) when you try to crank it over. Thanx for your response, but my starter is brand new.Plus, instead of just moving the steering wheel, i have to snatch on the wheel a couple time before it cranks. Any other ideas? :banghead: :crying: M7K7 06-13-2005, 01:20 PM I Have the same problem in my 1988. it clicks when i turn the key, but if i yank on the steering wheel, it starts to crank vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
