2000 Honda Passport Low Fuel Light - Idle Rough
johnjsa
06-05-2005, 08:58 PM
A couple of weeks ago I got a check engine light went to autozone & ut read EGR flow Excessive. Had EGR cleaned, replaced PCV valve & worked fine. Then a few days ago, the furl was down to about 1/4 of a tank & the low fuel light came on, blinked off & on & went off. Then the next time the check engine light came on but soon went off. Now today after church, my Passport which usually starts on the first lick, took a few times to start & then seemed to idle a bit rough & on the way home the low fuel light came on again briefly but went off, but I had half a tank of gas & now it idles rough it almost shakes. I am planning on getting it into the nearest Honda dealer which is 30 miles away, for a computer analysis to see what gives, no one works on Honds in our small town, but I wanted some input from you guys on this forum, which is a big help. Thanks.
amigo-2k
06-06-2005, 12:45 AM
sounds like you need a new fuel sending unit and you have a bad intake manifold gasket. See the FAQ's for more info.
