Car leaking white liquid Help
jnarowski
06-05-2005, 11:21 AM
I just drove my car home today, and when I parked it, it started leaking clear liquid. It appears to be water but I am not sure. It is coming from what appears to be part of the suspension. I do not know if this is normal, and what the problem would be if it isnt could somebody help?
http://www.itsthatbad.com/images/carimage1.jpg
http://www.itsthatbad.com/images/carimage2.jpg This photo shows the front right tire and the leaking part that connects to the tire.
94hondaacc
06-06-2005, 10:03 AM
DId you have your a/c on. Your A/C causes water to leak out due to the condensation. but this is normal. the only other clear liquid I can think of is brake fluid, so check the fliuid level. if you can touch a drop the liquid, if it feels like water, no problem, if its oily then you have to get it checked out, good luck.
