1989 Iroc Rear End 9bolt
SMOKEY818
05-31-2005, 06:44 PM
Okay i could get this 9bolt rear end from a 89 iroc, now my question is how much stronger is it than the 10 bolt.
89IROC&RS
05-31-2005, 11:28 PM
the 9 bolt is a helluva lot stronger than the 10 bolt. Its comparible to the Dana 44 rear end. The 9 bolt has surveved behind high performance big blocks that would have shredded a 10 bolt. There are many reasons for this aside from the larger ring gear. such as a smaller distance between the carrier bearings, and no C-clips to hold the axles in place. however to install it in your car youll also need to get the brake master cylender and proportioning valve from the doner car to make the disk brakes work properly, youll also need the e-brake cable i believe. but i could be wrong on that one. There is only one place to get parts for the rear end that i know of.
www.9bolt.com
Link85x
06-01-2005, 09:19 AM
89, say if i were to get a 9 bolt from the junkyard, is there much after market, say if i wanted to restore/rebuild it? That website looks like it might be out of business, it just looks old.
89IROC&RS
06-01-2005, 02:48 PM
sadley there is little to no aftermarket support for the rear end because they are so rare. that website is current, ive emailed and talked to the guy who runs it, hes answered alot of my questions about the rear end, ill try to post my information on it in my next post if i can. the only aftermarket place other than his website that may have something is www.taperformance.com (i think thats it ill have to check) but they were making a diff cover with carrier main cap suports built into it. kinda a carrier girdle so to speak. other than that, www.9bolt.com is the only place i have found that can get you parts. There might be some australian aftermarket sources but i havent found them. (the rear was an aussi design and was used over there far more).
89IROC&RS
06-01-2005, 02:51 PM
The Borg Warner 9 Bolt Rearend is actually called the M78 Rearend or "78 series". It has been made since the late 60's in Australia by a company called BTR Engineering Ltd. BTR was bought out by Borg-Warner under which company name the rears were produced for our cars. In the last few years Borg-Warner was bought out by Dana Corp. and the rears are still produced by Dana today in the same BTR factory under the "Spicer Axles Australia" name. www.spiceraxle.com.au/products.htm#srd
The rear is offically rated @ 220 kW = 295 HP
@ 435 Nm = 320 lb/ft
It can support a GVW of 2740 kg = 6041 lbs
The above ratings seem to be a bit conservative, as one member I know of has one that has survived the abuse of a 500hp/500+ lb/ft Big Block for a few years now. Being a 4 pinion design adds strength and as noted on his site www.diffsolutions.com the 9 bolt uses a shorter distance between bearing caps than the 10 bolt giving it added strength.
All 9 bolt rears for f-bodies use 28 spline axles.
Another advantage over the 10 bolt is it uses pressed on tapered axle bearings allowing the axles to be bolted in instead of using c-clips. I've heard several people say the 9bolt is stronger than the Dana 44. I do not believe this because in my 3 years of accumulating info on this matter, I've never seen one shred of FACT to support it. The dana 44 uses bolt in axles and has a larger 8.5" dia. ring gear versus the 9 bolts 7.75" dia. ring gear. Most, if not all Posi Dana 44's built for camaro's were 4 pinion versions also. Dana 44's were used by GM as service/warranty replacements for problematic 9 and 10 bolt rears, then offered them thru GM Performance Parts, and they were then used on the 91-92 firehawks if that tells you anything.
85-90 9 bolt equipped f-bodies were available with either standard open differentials or limited slip versions as well as several different ratios including: 2.77, 3.08, 3.27 (G92 w/auto), 3.45 (G92 w/stick), and a few 3.70 ratio's came in some 85 & 86 Firebird's w/L69, stick & G92=Very Rare!
3.27 and numerically higher gears will not fit on 3.08 and numerically down carriers. If you have a 2.77 or 3.08 rear and want 3.27 or higher you will have to get a 3 series carrier. www.9bolt.com sells them new but he's steep and that is if he feels like selling you one.
The "Limited Slip" or "posi" rears used on f-bodies used what is called the "Seperated Cone Slip Resistant Differential".
They also make a better version called the Hydratrak SRD but it uses a different spline count on the axles preventing it from being a direct swap into our rears
Vehicles originally equipped with the 9 bolt rear:
Australian made cars: Certain models of Ford Falcons since 1971, Holden Commodores from 1986 thru 1991, Chrysler Valiants since 1971, certain Aussie made Toyota Corrollas & Coronas, Nissan R31 Skylines/Pintaras & certian Datsun's, Mitsubishi Sigmas, Leyland P76s ...1997-up Morgan Plus 8s have the Hydratrak version. In the UK the rears were used on certain Vauxhall models and Jensen-Healey's.
I've also heard that Ford uses the 9 bolt center section in their Escapes and Mazda Tributes, but I haven't verified it yet.
The Nissan Austraila PN for 3.9 gears is 38100-J7100
3.7 gears were used in R31 Skylines with manual trans, the PN for those gears is 38100-J7110
4.1 gears were used in R31 Pintara's (manual or auto) and the PN is 38100-J7000
Holden's and Fords got nothing shorter than 3.45 gears AFAIK.
In 1998 the Australian magazine "Street Machine" did a series of articles on this rear axle, I am still waiting for my copy of those articles to arrive.
Here is some info on checking and tightening them up by using shims. This info is from a post originally done by Karl Hunter and info provided by Miles from 9bolt.com.
The posi units of 9 bolts will wear. One of the most common reasons a 9 bolt fails is due to excessive backlash between the ring gear and pinion (usually due to worn out pinion bearings or improper pinion preload) or between the side gear and the pinion gears (usually due to worn out brake (ie posi) cones). Either of these usually results in broken gear teeth.
TESTING THE POSI
1. Place transmission in Park (or low gear for manual transmission).
2. Raise rear tires from the ground.
3. Lock one wheel from rotating.
4. Measure torque required to rotate opposite wheel.
5. If torque is less than 35 lb ft unit should be replaced or rebuilt.
CARRIER SHIMMING
First you need to find shims. There is no G.M. part for this, you just have to use whatever is available.
You need a variety of thickness of shims ranging from .010" to .050" in .005" increments. Some types of differential pinion bearing shims will work for this purpose, but use ones with a Max Outside Diameter of 2.5" and a Min Inside diameter of 1.5"
Mount one axle in a LARGE bench vise with splined end pointing straight up. The vise must be securely mounted to a strong table or work bench.
Place the differential carrier over the splined end of the axle with the ring gear teeth facing downwards.
Mark the 2 halves of the housing for alignment during re-assembly.
Loosen the bolts that hold the housing together. (the ones with the 7/16" head) It is not necessary to remove the ring gear, however if it is to be removed it should be marked prior to disassembly for proper re-alignment.
Once all the bolts holding the housing together have been fully loosened remove the upper carrier housing from the assembly. All the internal parts for the differential are now accessible. Each half of the carrier houses a friction cone and a side gear. All parts must be kept in order. Place match marks on the cross shaft and spider gears prior to removal. There should also be a spring pack in the centre of the assembly, which should have 3 springs together. G.M. recommends replacing these springs anytime the differential is apart, but if they are not broken this should not be necessary. If any other parts are broken it is recommended to find a complete replacement for the carrier, however single parts such as side gears or spider gears may be replaced individually in emergency situations. If a friction cone is worn to the point where the end of the cone is contacting the housing at the inner most point (it will be evident by the wear pattern) then the carrier must be replaced.
Place the friction cone in its respective half of the housing and insert a shim between the side gear and the cone. Place the cross shaft with spider gears on top of the cone and gear in the housing. If the cross shaft seats fully into the housing and there is play between the spider gears and the side gear then use a larger shim. The idea is to remove all play in the gears while still allowing the cross shaft to seat fully in the housing. If too big a shim is used then the cross shaft will not seat properly and the assembly will bind causing the differential to act like a spool or possibly cause premature failure.
Install brake cones in the differential case. Measure the distance from differential case mating surface to flat surface on brake cone when it is fully seated. This is done to determine the size brake cone shim required.
Distance Measured In.(mm) Shim Size In.(mm)
1.155-1.162 (29.34-29.51) No shim required
1.163-1.167 (29.54-29.64) .005 (.13)
1.168-1.172 (29.67-29.77) .010 (.25)
ADVANCED SETUP- SOFT FEEL shim each side until all play is removed and cross shaft seats properly in case, then remove .005 to .010 inch of shim.
ADVANCED SETUP- HARD FEEL shim each side until all play is removed and cross shaft seats properly in case and add up to BUT NO MORE THAN .005" of shim per side. This will provide additional preload to the differential that is not possible unless the gears themselves are loaded. RECOMMENDED FOR RACE USE ONLY. If the vehicle is to be street driven on a regular basis it is not recommended to preload the gears.
The optimal amount of shim for Street-Race use is the point where all play is removed from the side gears and the cross shaft and spider gears seat properly in the housing. All one wheel peel will be eliminated and the differential will still operate normally.
RE-ASSEMBLY (This part is easier with 2 people)
Place components into case half without ring gear and place onto axle mounted in vise. It is important to re-assemble the case using the axles to align the internal components, otherwise the splines on the side gear and the friction cone may not be aligned and it will be impossible to insert the axle when the case is tightened.
Place cross shaft with spider gears into lower half of case and insert preload springs and spring plates.
Place other side gear on top of spider gears, then place the correct shim on top of the side gear then place the friction cone on top. All components should now be in place and in correct alignment. Double check to make sure there are no left over parts.
Place other case half over the assembly. Make sure the alignment marks line up.
Insert all bolts and hand tighten. The case may not seem to go together at this point, don't worry, the preload springs have not been compressed yet.
Insert other axle shaft into upper case half and align friction cone and side gear. Do not remove axle shafts until carrier is re-torqued.
Tighten bolts little by little in a cross-pattern until the 2 case halves seat together then torque to 29 Lb.Ft.
Remove axle from upper case half (you may have to hammer it out) and remove carrier from axle mounted in vise.
Re-install carrier into housing making sure all parts are re-installed in original order. It will be a tight fit, one side bearing shim will have to be GENTLY tapped into place with a hammer, preferably a brass faced, or use a brass drift. Install all components except one side gear shim, then do the remaining side gear shim last and gently tap it into place.
Install bearing caps in original positions and torque to 40 Lb.Ft.
Install axles. They may need some persuasion with a hammer to fully seat. Tighten axle retainer bolts to 36 Lb.Ft. Don't forget the caliper mounting plates.
TORQUE SPECS:
Pinion Bearing Preload-Inch Lbs. NEW 12-15 USED 6-7
Ring Gear Bolts-Ft Lbs. 65
Bearing Cap Bolts-Ft Lbs. 45
Axle Retainer Bolts-Ft Lbs. 36
Rear Cover Bolts-Ft Lbs. 25
Carrier Half Bolts-Ft Lbs. 29
Fluid Capacity with stock cover 1.7 qts
Backlash-.006-.010 inch
Set up the gear sets with a little more toe pattern and on the low side for backlash (preferrably between .006-.008). This is a little stronger, but also makes more noise. Also, if the backlash is set too low
the gears will bind up when hot.
Here's a link to Slow89Iroc-Z's post on his setup experience AND the exploded views and pn's of the 9bolt rear from the GM parts catalogs:
http://thirdgen.org/techbb2/showthr...threadid=239424
RATECH www.ratechmfg.com/gmstandard.htm
Great source for individual parts.
Pinion Shims 1104*
Severe Duty Pinion Shims 1133*
Carrier Shims 1105
Crush Sleeve 3101^
Solid Pinion Spacer 4114 (Replaces 3101)
Pinion Seal 6120
Pinion Nut 1508
RG Bolts 1303*
Gasket 5124
Inner Pinion Bearing? Check yours and then check with ratech-they list 3 different ones for some reason
Outer Pinion Bearing 8001*
Install Kit (w/0 bearings) 130K
* Denotes same as 7.625" 10 Bolt
^ Denotes same as Ford 8" & Dana 35
Reider Racing/Precision Gear- http://www.reiderracing.com/home.htm
Best price I've found for an overhaul kit.
They also sell 3.70 Gears
US Gear/Strange 3.70 Ring/Pinion Set Part # 01-878370BW sometimes you can find one somewhere cheap on clearance.
Auto Zone has the cheapest price on Timken Axle Bearings (8.99 each) Part # Set-9. You'll need to replace the seals also, available seperately timken part # 710179 for the passenger side (9.99) and 224255 (3.99) for the driver's side.
They also sell Timken pinion seals part # 7457N (15.99)
Randy's Ring and Pinion sells Yukon Brand 3.70 gears and install or overhaul kits. They are the best price for them with an overhaul kit and new axle bearings and seals you'll find, but I hear the overhaul kit has some mismatched parts.
Ratech or Reider have competitive prices on their overhaul kits and their parts are all top quality including Timken Bearings and Seals.
Larry Burd [email protected] sells shims to tighten your posi.
And lastly, DiffSolutions www.9bolt.com - Miles is the only vendor I know of who sells ratio's other than 3.70. Somehow he's got a hookup in Australia and can get the OEM Holden/Ford stuff imported.
He offers used sets from time to time and offers new 3.27, 3.45, 3.73. 3.91, and 4.10 ratios. They're high, but they're OEM parts. He also offers new 3 series carriers. He can get shims and install kits but his prices are considerably higher than others. Also, You'll have to convice him you're serious about buying something before he'll email you back.
If you desperately need small parts for inside the posi carrier and can't find them locally you may try Dick Craft.
Craft Differentials
5 Peel Street, Granville
NSW, Australia
Phone 61 2 9637 1973
ADDING STRENGTH TO A 9BOLT REAR:
This is what I've done to mine, my car is not finished so it hasn't been tested yet.
-Replace bearing cap bolts with ARP 190,000 psi cap screws. I ordered mine direct from ARP. Cost me like $15 for the 4 of them. Cheap insurance. You could use studs instead of bolts for slightly more strength. TA Performance will be offering a bearing cap stud kit soon.
-Ratech Solid Pinion Spacer 4114 instead of using crush sleeve.
-Ratech Severe Duty Pinion Shims 1133. Adds reliability plus makes changing gears easier.
-Dry Film Lubricant on ring and pinion as well as internal carrier gears. I used Tech Line brand and applied it myself. Just check with your wife first before using the oven to cure it.....trust me! Seriously though, it's cheap insurance and you can get it from Jegs or Summit.
-Check posi and shim/tighten if necessary.
-A support cover would be a great addition and I'm working with TA Performance to try to get one made. Hopefully soon!
-Another option is Moser Axles. You'll probably break the gears first, but if you think it's necessary....they'll make you a set. I didn't think they were worth it.
I installed them myself and it took me about 4 hours. I went from 2.77:1 series 2 carrier to a 3.91:1 series 3 carrier. I set the backlash to .008in, set the pinion preload to 14ft/lbs, and I had to use .060in under the pinion to get a good pattern. Seemed to be a lot but I just went for a drive and the gears are silent. Just to let you all know DO NOT buy the install kit from Randy's Ring and Pinion they DO NOT provide the correct carrier shims or a pinion nut. Get the kit from Raytek or from 9bolt.com. Also only torque the cap bolts to 45-50ft/lbs. I tried to torque them to 65ft/lbs as stated in the directions in the install kit and the bolts just snap.
Later
Whew, that was alot of typing.....
Link85x
06-01-2005, 03:22 PM
Damn, 89. I hope you didn't type all that, my hands would be hurting!! I'll read it though.
89IROC&RS
06-01-2005, 03:26 PM
lol, copy and paste is your friend ;)
Earlsfat
06-01-2005, 03:50 PM
All I can say is.... WOW!
Question, I have a 10 bolt drum brake rear in my maro. A friend said I can take a rear end out of say an 81 with disc brakes and do a "conversion" that way.
Is that do-able? If so, what else would I be looking to get off the donor car to make it work?
(I think someone posted a site that has the Chevy parts that interchange between the various years and models.... wouldn't happen to be able to put it up again would they???)
89IROC&RS
06-01-2005, 03:53 PM
they are both second gens, so i wouldnt see why not. im not to familiar with the second gen braking systems, so im not entirely sure what parts you would have to swap to make the setup work though.
Link85x
You should ber able to swap between 70 and 81, considering those were the years of the 2nd gen. It's should just swap right in. I know 82-92 for 3rd gens, everything was interchangeable.
SMOKEY818
06-02-2005, 04:12 PM
okay i have a 96ss rear end in my maro is it worth me switching to a 9bolt.
89IROC&RS
06-02-2005, 04:19 PM
nope, the 9 bolt is stronger, but youd need to modify the axle length to match the needed specs of the fourth gen.
SMOKEY818
06-02-2005, 04:51 PM
why would i need to modify the axle length for a fourth gen, if i have a third gen? :confused:
89IROC&RS
06-02-2005, 05:17 PM
ignore that im retarded, you said 96SS and i ran with it. swaping to the 9 Bolt would be stronger as a rear, but you have to take into account the parts availability for it. If you dont mind the hassle of finding parts, id say go for it, if you preferr being ableto have any shop do the repair work, stick withthe fourth gen rear.
bill dole
11-08-2008, 03:56 AM
Hi there,
Being from Australia I know that Ford Falcons from 1967 and Chrysler Valiants from around the same time made here as well as Chrysler Centuras used the 9 bolt with different size crown wheel bolts all 78s will fit in the same housing providing for a cheaper solution to a 9" which is over kill unless you have an abundance of horsepower.We have some pretty awesome commodores the put out 1700 rear wheel horespower using the 78 with no trouble at all. Hope this is of help.We can get ratiosfrom 2.75,2.92,3.08,3.23,3.45,3.7,3,89,and 4.11 over here in both 25 and 28 spline.
regards Bill Dole
