93' Grand Cherokee Suspension
chris8727
05-31-2005, 06:41 PM
My shocks are wore out. I thought since I had to spend some more money I would lift it about 3 inches.
I do not 4 x 4 for the fun of trail riding but do use it everyday at Work, or when I Hunt and Fish. Mostly driving over and through washouts on the Beach or over uneven land.
I would like a smooth highway ride and something smoother than the bumps I get now when driving in 4 wheel drive...
I have read some of the other threads on suspension and websites to buy it at but could anybody suggest something that they have actually used. My budget is about 500.00 dollars.....
Thanks Alot....
fredjacksonsan
06-01-2005, 11:28 AM
For mild off roading, you probably don't need a 3" lift, but you can find kits on places like quadratec.com, 4wd.com, and other sites. Do a Google search for Jeep lift kits and you'll find a bunch.
chris8727
06-01-2005, 03:31 PM
Ok Thanks. Since I need shocks I think I'll just try one of those kits with 2" spacers and new shocks. I just hope my coil springs aren't worn out though.
Does anybody know if the spacer kits work out or are they to bumby....
fredjacksonsan
06-01-2005, 03:34 PM
What kind of spacers are you talking about? If they're the ones that you twist in the middle somewhere on your springs, I wouldn't recommend them because they fall out.
If they're the kind that sit on either end of the springs, it might be the mild lift you're looking for. Make sure to get shocks that are longer, too.
chris8727
06-02-2005, 01:58 AM
The kit includes the shocks and the spacers. The spacers are the type that go on top or bottom not the twist in type.....
fredjacksonsan
06-02-2005, 08:09 AM
Cool; I had the twist in type on a (very) older car, checked in 3000 miles and they were just gone.
SteveB05
06-02-2005, 09:04 AM
If you could squeeze out a few more bucks...this is what I have and I LOVE the ride both on and off road. They are soft though, if you tow or carry big loads, this isn't for you...
www.suspensionconnection.com Tuff Country 3.5" EZ-Ride - 500.00
www.SummitRacing.com Rancho RS99239 adjustable rear shocks 180.00/pair and Rancho RS5194 front shocks - 80.00/pair
www.rocky-road.com Adjustable front track bar - 110.00
At the time I bought my stuff, these were the best prices around, but that may have changed...do some shopping.
fredjacksonsan
06-02-2005, 09:08 AM
Steve, do you have a picture of your JGC? Might be good to compare..... :)
SteveB05
06-02-2005, 09:18 AM
I'm at work, but I'll post one later today.
fredjacksonsan
06-02-2005, 09:21 AM
Cool. :thumbsup:
chris8727
06-02-2005, 06:13 PM
I do tow a 20ft Ranger Bass Boat. should I go with somethink a little stiffer ?
SteveB05
06-02-2005, 07:31 PM
Here is my ride...
http://files.automotiveforums.com/gallery/watermark.php?file=/503/302379Jeep.jpg
SteveB05
06-02-2005, 07:34 PM
No, boats normally don't have too much toung weight. You shouldn't have an issue with that. I pull my 17' run about with no problems. I did pull a friends 96 Bonneville on a u-haul trailer...that was too much :(
fredjacksonsan
06-03-2005, 08:00 AM
Here is my ride...
Looks good Steve, thanks for the pic!
chris8727
06-03-2005, 10:42 AM
Good to know....
That 3.5" lift doesnt's require any additional items or alterations other than you listed ?
I think I can come up with the extra money for that....
SteveB05
06-03-2005, 11:46 AM
Nope. Nothin' else requried.
cookie2
06-04-2005, 07:46 AM
WOW! I am jealous, looks nice Steve! Want to trade? giggles
SteveB05
06-04-2005, 08:09 AM
Thanks! No, I don't...you have that shifting problem I wish I knew the cause of...but I don't have any Idea at this point.
chris8727
06-04-2005, 10:57 AM
Hey I am going to order that suspension today.
Are there any special tools that I need to install it...
SteveB05
06-04-2005, 02:40 PM
Not really. A complete basic set will suffice. But you will need some muscles and it will take you and a friend a full day to do. Are you going to get the track bar too? I would suggest it. I ran without it using the relocating bracket in the kit and had some pretty bad bump steer. If you change that, you will need a "pickle fork" or joint separator and don't put the relocating bracket on the front. I'll take some close ups of my suspension later and post them so you can use that as a guide.
chris8727
06-04-2005, 04:07 PM
Ok man thanks, That sounds good...
chris8727
06-04-2005, 04:21 PM
That easy ride suspension looks like it is on sale for $305.00 its on the front page in that link that you posted.....
SteveB05
06-04-2005, 06:29 PM
Don't order that one...thats for a Cherokee (Leaf spring rear suspension). GCs have coils all the way around and it is $509 right now.
The one thing I didn't care for, but have yet to do anything about is the relocation brackets for the brake lines. They work, but are kinda cheap.
http://files.automotiveforums.com/gallery/watermark.php?file=/500/302379Suspension1-med.jpg
No change required on the sway bar links. I haven't had any trouble with them.
http://files.automotiveforums.com/gallery/watermark.php?file=/503/302379Suspension2-med.jpg
The chrome looking tube is the new track bar. Notice it is in the factory mount on the axle side.
http://files.automotiveforums.com/gallery/watermark.php?file=/503/302379Suspension3-med.jpg
On the frame side, you will need to take the bracket off and drill out the taper for the new mount. Not difficult but you might need to buy a $20 drill bit for it.
http://files.automotiveforums.com/gallery/watermark.php?file=/503/302379Suspension4-med.jpg
Here is the reloacating bracket for the rear track bar. Works fine.
http://files.automotiveforums.com/gallery/watermark.php?file=/503/302379Suspension5-med.jpg
Over all, if you follow the directions in the kit, its a straight forward upgrade. Enjoy!
SteveB05
06-04-2005, 06:35 PM
Cookie2...
My daughter is a little green eyed over my Jeep as well. Here is her '89 Cherokee Loredo we got her a month or so ago. She is going to use my old springs with some 1 3/4 spacers and add-a-leafs to bring hers up and level.
http://files.automotiveforums.com/gallery/watermark.php?file=/503/302379AmbersJeep.jpg
cookie2
06-05-2005, 07:49 AM
Steve,
Did I understand you correctly when I get my shifting problem fixed we can trade? Hurries to fix her problem! giggles
