Ball joint
drftrman1977
05-31-2005, 05:39 PM
I have a 1993 k1500. I have replaced the front axles, now the bolt on the bottom of the upper ball joint spins when i try to tighten the nut. can anyone tell me how to get around this.
2000CAYukon
05-31-2005, 05:59 PM
One option is to tighten it when the wheel is on it and the jack stand is removed. With a load on it, it won't spin.
Otherwise, put a floor jack under the lower control arm and jack it up so that there is a load on it. You can also use a pry bar on the upper control arm and pry the arm down while you tighten the nut.
//2000CAYukon
drftrman1977
05-31-2005, 06:15 PM
thanks
