easiest and cheapest way to change motor mounts
Google
Web AF
hywypatrl05
05-31-2005, 02:33 PM
does anybody know the easiet and cheapest way to change my lower motor mounts??? all help is GREATLY appreciated because its vibrating the crap out of my car.
1992 Grand Am 2.3L Quad 4 OHC
skibum1111
05-31-2005, 05:05 PM
To change the drivers side, jack and block the car, take the drivers side wheel off, put a jack under the transmission and take the pressure off the mount. one end bolts to the frame rail in front of the tire, the other end is attached to the transmission. On the passenger side, use a block with your jack and take the pressure off the mount, take out the nuts holding the mount to the body, then the four bolts holding the mount to the bracket on the timing cover. these are the difficult ones, i had to drill them out, and to do that the motor had to come out. good luck
hywypatrl05
05-31-2005, 08:23 PM
well....thanks
Google
Web AF
