Bulb replacement240NIZ 05-31-2005, 11:59 AM I have a 93 coupe, I was wondering if anyone one of you could help me figure out how to remove the front side marker (driver side) so that I can replace the bulb. I opened the hood and it doesn't seem like there is any access from the inside. Do you just pry the side marker off. :confused: HoosierDrifter 05-31-2005, 01:41 PM k.... remove the plastic inner fenderwell...and reach in threw the fenerwell, then you will need to push in on one of the sides in to unclip it to just pop the whole thing out... replace the bulb and snap it back in SHIFT_KA24DE 06-02-2005, 12:43 PM all you need to do is push the light housing forward. it'll come right off. IIRC it says so on your driver's manual. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
