88 S-10 cranks/will not fire/has fuel & spark
Google
Web AF
kevleasa
05-30-2005, 12:09 AM
HELP driving S-10 acted like it was out of gas. Towed home added fuel,
no help. Changed fuel filter,ECM,cap and rotor,pick-up coil,injectors clean.What do I check next.no crank senor.At least no one can steal it.Been tring to fix for a week now.Any help would be nice.
Thanks,
Kev
jackass#1
05-30-2005, 10:17 AM
have you checked feul pressure(9 to 14psi)? how do the plugs and wires look? check for vaccum leaks. timming?
dmbrisket 51
05-30-2005, 03:40 PM
if you have fuel and spark, like jackass#1 said, check fuel pressure, check for vacume leaks, plugs, wires, cap, roter, and also check to see how "powerful" of a spark you have, ive had the problem b4 with having spark, just not strong enough to do anying... and timeing, the bushings at the bottum of the dizzy can sometimes go bad, havnt seen it but once or twice, but if you like to give her hell, you may have worn out the teeth and now its "jumped" timeing
kevleasa
05-30-2005, 06:27 PM
chenged fuel pump today,40$ for tester or 40$ for pump,after puting bed back on tried to start. did not start, still no fuel out of injectors. can put fuel into TBI and runs till fuel runs out. Now can not get it to turn over, battery good. When I turn key no gage lights or warning lights and doom light goes off. Checked fuses (all good) have power on left side of fuse block,till I turn key on then none. Fuse link mabe? Tried puting old ECM in did not help. Next going to put holes in floor and flintstone it!!!!
any idea's???
Thanks for any help,
Kev
jackass#1
05-30-2005, 08:40 PM
ignition switch.
kevleasa
05-30-2005, 10:39 PM
Thanks #1 will look in to that & let you know
kevleasa
06-01-2005, 01:31 AM
Found bad Battery,got new . Need to put new cables on too.Starter sounds like it is frozen. Put charger on 110 amp start and did not turn over starter. Will keep you posted. Origianl starter 230'000 on it . 30k on new motor.
kevleasa
06-01-2005, 01:33 AM
When put on110 amp lights and gauges worked.
redwheeler
06-01-2005, 03:19 PM
check power to fuel pump when key is to run and start
kevleasa
06-02-2005, 01:14 AM
New battery,new cables, turns over good,80lb oil pressure. No start. Need to check power at fuel pump(redwheeler noted).Pump does work when key is turned on. New start works well!!!Still no fuel out of injectors? Will check power at pump and post.
Google
Web AF
