how much boost safe on dohc zc motor3.1zxt 05-29-2005, 09:43 PM How much boost can I run on a dohc zc motor d16a9 it has 50 thousand miles and is running great. o0Quicksilver0o 05-30-2005, 01:35 AM its not boost its horsepower that matters. d series are good to about 250-260 whp but only 220-230 whp safely. Polygon 05-30-2005, 06:06 PM Also, you only want to run as much boost as you can without getting detonation. scottsee 05-31-2005, 12:42 AM sigh. boost is boost. airflow is airflow. if you have 20psi on a turbo that flows 10lb/min its not the same as 20psi on a turbo that flows 30. to ask what psi to run. first let us know the turbo!!! Polygon 05-31-2005, 11:45 AM Exactly, boost doesn't equal horsepower, airflow does. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
