Been Meaning to ask... what's your MPG?Sparsky 05-26-2005, 02:03 PM I remember when I first bought my truck I was getting about 32 MPG. It's been 4 years now, 2 accidents, 1 new Alt, 1 new cat, 2 new batteries, 4 new injectors, plus the normal plugs, filters etc. But now i'm only getting about 21mpg, and that's if i'm taking it easy. So I'm starting to wonder WTF happened. Just wondering what everyone elses MPG was at, so I know what to shoot for. Oh, I got a 2.2L BTW. OverBoardProject 05-26-2005, 06:46 PM If I don't go off roading about 25 with my carburated 2.8L Auto 4x4 Blazer. Try a full tune up, but also aparently the gas is getting even worst, so that could be your problem. xtrememeasures10 05-26-2005, 09:01 PM im running 30mpg average with 109k on my 2.2L Have you tried cleaning your Intake system? Sparsky 05-26-2005, 10:42 PM I have about 160K on mine. When I replaced the injectors I did clean out the inside of the intake manifold, but that was at 100k. Besides just the normal filter change no. How would I go about this? When I look down the intake tubes they all look pretty clean, don't know about that big tank that sits ontop of the fan shroud though. J-Ri 05-27-2005, 05:16 AM I've got a 93 4.3L auto 151,000 miles. Has HEAVY front end damage (the kid who had it before me smashed it into a tree). I patched the radiator with JB Weld, and did no other repairs (other than pulling the bumper back to almost where it should be), so it's less aerodynamic than stock. The frame is bent, throwing the tracking way off ("dogtracks" at least 4 inches), and the toe is set in too much. With all this going against me, I got 30.09 MPG the only time I drove a full tank highway (70 MPH), at that was with a headwind and going up and down hills. Have you replaced your 02 sensor(s)? If it's OBDI, it has one, OBDII has 2, for the 4 cylinder models. 95 or older is OBDI for sure, 98 or newer is ODBII for sure. 96 or 97 could be either. Sparsky 05-27-2005, 01:20 PM i know i have 2 o2 sensors. One right at the end of the exhaust manifold, the other right after the cat. The one on the manifold is a single wire and the one after the cat is a 4 wire. I do remember now getting a check engine code for the cat one, but erased it once and never came back. Figured it for just a glitch, and if it was really broke the stupid light would come back on. I don't trust the stupid light cause I get a code (forgot the number) that says my 4x4 over ride switch is bad. But I don't have 4x4. Ehh? balls_to_the_wall 05-27-2005, 10:54 PM I've got a 93 4.3L auto 151,000 miles. Has HEAVY front end damage (the kid who had it before me smashed it into a tree). I patched the radiator with JB Weld, and did no other repairs (other than pulling the bumper back to almost where it should be), so it's less aerodynamic than stock. The frame is bent, throwing the tracking way off ("dogtracks" at least 4 inches), and the toe is set in too much. With all this going against me, I got 30.09 MPG the only time I drove a full tank highway (70 MPH), at that was with a headwind and going up and down hills. 30mpg with a 4.3, up and down hills, with heavy front end damage....Damn...I get around 15-16mpg with my 4.3L 4x4.... Are you sure thats not a mistype? Later -Ryan OverBoardProject 05-27-2005, 11:07 PM Read J-Ri's acetone link, and it might help explain his mileage. I was probably only getting 15 - 18 on my 2.8L 4x4 with 4:10 or 4:11 gears before I tried it, and afterwords I was getting about 25. With the good carb that I finally got on my Blazer today I'm hoping on gettting better. Just to keep things fair. I use the U.S gallon for my figures balls_to_the_wall 05-27-2005, 11:32 PM Ohh, duh, I read the article, but I didn't put 2 and 2 together. I am wondering if I should try that...sounds like a plan to me. Later -Ryan movin2stereo 05-29-2005, 08:26 PM My ZR2 is getting like 10-12 MPG.Terrible! m3gumby 06-06-2005, 09:46 PM what does a 6 cyl engine get? how much hp does a 4 cyl have and how much punch can you pack in one of those? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
