question about compression tests
bob stone
05-25-2005, 08:59 AM
ok just did a compresion test on my car and all clinders had 177 I belive +/- 2.5 they where almost identical the +/- is mostly as the gague might have been off, cause they all came to that number, this is good right, and by knowing this what do I know is NOT wrong with my engine :P
Thanks
Bob Stone
ps if they all are good that means i do not have to do a "wet"? compresion test, someone told me once that puting oil in the cilinder will tell me more info when doing this test
JekylandHyde
05-25-2005, 10:56 AM
Your engine appears to be healthy :)
Those are good numbers. All adding a touch of oil does is let you know if your rings are bad. I would only bother doing that if you had a cylinder with low compression.
A leakdown test will tell you even more about the health of your engine.
bob stone
05-25-2005, 11:54 AM
how you do that ? we got a nice auto shop on base but it is do it your self for the most part
JekylandHyde
05-25-2005, 11:57 AM
Leakdown test is realtively easy to do ... but you need an air compressor and a leak down tester :)
Basically you are psuhing a preset level of compressed air into the cylinder and measuring how much is leaking out. Let's you know if it is good-n-tight.
