high idlemiecow 05-24-2005, 07:42 PM my 90 3.1 is idleing very high, if you put it in gear and drive it, it will go down to normal but jumps back up here and their.. i just replaced the throttle position sensor could it be another bad sensor ? thanks for any help DaMoNe6969 05-25-2005, 06:39 PM might have a bad idle air control valve, or a vacuum leak somewhere.. check all your hoses/connections DaMoNe6969 05-25-2005, 06:44 PM also, if the problem wasnt happening before the TPS was changed, it probably just needs to be adjusted.. miecow 05-26-2005, 10:35 PM how do you adjust the tps? miecow 05-26-2005, 10:36 PM on mine its pretty much screw it on and plug it in vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
