check oil light on
Google
Web AF
homer9901
05-24-2005, 01:14 PM
the check oil light is on all the time and the oil is full. but if i turn the car off after it has been runing the light will go off.
Is this problem common and if so what is the fix for it or do i just have to live with it.
Thanks :confused:
Ridenour
05-24-2005, 01:54 PM
Try opening your fuse panel cover and push and hold the "reset" button for 3 seconds. It is a button to reset the oil light and check tire pressure light.
Chameleon-kat
05-24-2005, 03:38 PM
My 96 did that for a while also, right after oil change. I'm not sure if it was because I overfilled it a tad, or the crummy filter I put on. Anyway it got over it after awhile and stayed out (mine is getting old and a little oil tends to dissappear from it :p )
justin0717
05-24-2005, 05:50 PM
my 96 did that and the oil level sensor was bad. i just unplugged it and connected the two wires, and it went out for good.
justin0717
05-24-2005, 05:55 PM
mine was on on my 96, the oil level sensor was bad. i just d/c it and crossed the two wires and its been out for good.
brots06
05-26-2005, 06:36 PM
i had the same problem, you have to turn the key to on and put the car in neutral and then press the gas petal 3 times fully, and then turn the key off and start the car and the light will be gone. Sounds goofy but it really works!
justin0717
05-26-2005, 09:09 PM
thats for the change oil light not the oil level light
totonicki11
11-13-2005, 12:54 PM
I just posted a question regarding my "Change Oil" warning light because I've been trying to reset it for two days now...
OMG!!!!
What you said to do worked! What a stupid car...lol.
Google
Web AF
