95 2.2 auto wont shift from 1st, and no speedo!!! HELP!!jbronc88 05-24-2005, 12:39 AM I have a 95 cavalier with an automatic trans and the 2.2 engine. It will shift from park to reverse and to drive, but it will not come out of first gear. The speedometer does not work at all. Every once in a while it WILL shift out of first... and the speedo will jump up to the actual speed (which is around 40). Whenever it doesn't shift the speedo doesn't work. It has to be related somehow. I replaced the speed sensor on the trans and it didnt fix it. Please help!! Classicrocjunkie 05-24-2005, 12:41 AM hmm.... sounds like your shifter cable might need to be adjusted possibly. Also check and make sure the connector into the tranny dosn't have crap on it or some how got inside of the plug. jbronc88 05-24-2005, 12:53 AM The cable is adjusted properly because it wont shift no matter what position i put it in. And remember, the speedo wont even budge from 0 when it isnt going to shift. but thanks for the reply! 4dr92cavi4cyl 05-24-2005, 02:13 PM Sounds like a tranny problem to me, or maybe the wire to the speed sensor is shorting out or something. If you are sure the wire is OK then try resetting the computer by removing the negative battery terminal for about 30 seconds. OverAllComa 05-24-2005, 05:48 PM VSS = Broke Nitrous_Boy 05-24-2005, 05:54 PM i had the same problem with my gf's old taurus. i changed the fluid and the filter and it started to work again, but then it fucked up worse so it could be your tranny. smack it a good 12 times with your hand and call it a few names like "asshole" "stupid fucking car" stuff like that and it might help a bit Ryan066 05-24-2005, 07:02 PM if cable is adjusted properly and everything is where its supose to be your tranny is prolly fried. what about the N safety switch, wouldn't have anything to do it with eh? Nitrous_Boy 05-25-2005, 07:14 PM no idea to me. dis over my head but thats nothing new vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
