my windows , fan , and radio stop working !
Google
Web AF
abeltwo
05-23-2005, 09:05 PM
i have no clue what to do . i change the fuse for the radio and now the it works but i still dont know what to do after that clueles please help!!!!!!
abeltwo
05-23-2005, 09:26 PM
please please help
Twizted_3KGT
05-23-2005, 09:39 PM
Well...so...you changed the fuse for the radio...and then it worked. Maybe if you change the fuses for the other things, they will work.
I underlined what I thought would be common sense.
Daniel Doerksen
05-23-2005, 10:00 PM
lol :). . . what probly happened was u tripped ur system sum how.. and blew a couple of low amp fuses.. hence windows.. just a theoritical gues
did u put anything new in lately??
abeltwo
05-23-2005, 10:07 PM
i checked them all . but thanks for being a jerk (twisted ) and ya i did install a new alternator and a new water pump . why ?
abeltwo
05-23-2005, 10:12 PM
and it was working good for a couple of weeks before this . it like 100* in my car in the middle of the day .
Daniel Doerksen
05-24-2005, 01:00 AM
well fuses blow because the get to hot.. becuz there is too much amperage flowing throught them and they melt... whihc u probly no.. now is it possible u got a alternator thats overchargen ur system slightly.. and the heat could have been the toppeling bird
abeltwo
05-24-2005, 02:35 AM
cool thanks! do you know of a quick fix for the windows , i cant stand the heat !
Daniel Doerksen
05-24-2005, 05:17 PM
yea i no one but whether or not its worth it is another thing...
u can pull the door panel off and grab a positive wire from the fuses box and supply the window switch directly with power... it should work
but fixing the problem might be quicker.. get a multimeter its a must for electrical issues
abeltwo
05-24-2005, 07:23 PM
dude im almost going to pay some one to rewire my whole car ! how much is that you think?
Daniel Doerksen
05-25-2005, 12:49 PM
i dont tmhink its nesseary.. and it will cost a hell of a lot of money for the entire car when u only problem is accesory systems.. pick up a manual for ur car.. do u no how to follow eletrical schematics??
.. i mean if u got the money u can get someone to do it for u.. thats done it before.. but ur just goning to be depending on other ppl to fix problems.. tyhat if u spent sum time to learn u can fix them.. electrical is all logic.. but.. on the other side its a 4th gen car right?? so the systems are all connected to damn computers that screw with ur life.... whihc just brought up another idea.. ask ur cars computer.. it might tell u the problem.. with the ignitoin switch.. i dont remmeber how but i look for u.. sumthing about turn the switch on then off then on then the check engine light morse codes the diagnosis
Daniel Doerksen
05-25-2005, 02:48 PM
hey i found it.. follow theses instructions and it will diagnose ur car.. tell what the problems are
this is for fbodys 3rd gen.. im hoping that it will be the same for 4th gen firebirds
http://pageperso.aol.fr/sdgreyefdbv/section+technik/trouble+codes.htm
scroll down a bit and u will find the possible outcomes....
abeltwo
05-25-2005, 05:51 PM
12 and 24 came "no distributor pluses" and "vehicle speed sensor" ? what does that mean ?
abeltwo
05-25-2005, 05:52 PM
Ohh and thank man your doing alot more than most would!
Daniel Doerksen
05-25-2005, 06:40 PM
hmm the 12 is because ur car wasnt on.. so that doesnt matter.. becuz ur not suppose to have it running..
and 24 means.. well ...
im pretty sure that is working
ur sure all fuses are good
abeltwo
05-25-2005, 07:29 PM
ya but my idle is always jumping but maybe that is just the choke getting stuck i dont know ill check everything once more !
Twizted_3KGT
05-26-2005, 06:49 PM
lol no problem, sorry I was bein a jerk to everyone that night....now did everything stop working all at once, or was it seperate??
abeltwo
05-27-2005, 04:14 PM
hey thanks again my window work now i didnt real anything but play with the wires so i guess there is a short but now i know where ! thanks
tri-power
05-27-2005, 09:45 PM
Should work for gen 4 up to 95 or 96
Google
Web AF
