Switching wheel size from 17" to 16"
batmobile78m
05-23-2005, 03:59 PM
Anyone done this?
Anyone know if there would be any practicle difference?
Chameleon-kat
05-24-2005, 07:47 AM
Should be able to do that, however you may find the 215-70r16 (think thats the standard size tire for Teks with 16 inch wheels) has a rather limited selection for available tires. Not many vehicles have that size
batmobile78m
05-24-2005, 07:06 PM
that way the width is the same and there are many more available than the 235-55r17's that it came with.
Chameleon-kat
05-27-2005, 06:44 AM
Some other thoughts on switching: Assuming you would keep same outside diameter for 16 inch tire (keeping speedo happy and not messing with shift points) the 16 inch would have a little larger air cushion, perhaps a little better ride and slightly less chance of wheel damage if you happen to hit a pothile the size of texas. One downside (depending on stiffness of sidewall) may be a little less cornering handling.
