Lubricatin locations on Century 2000
Peter Solarik
05-20-2005, 07:45 AM
Since I am doing the oil changes myself, I would not want to miss the lubrication points that oli change facilities normaly lubricate. Are there any lubricating points on the chassis/underside?
Thanks
Peter
Thanks
Peter
Flatrater
05-20-2005, 07:44 PM
Peter your Century has no grease fittings underneath.
But it would eb a good idea to spray your door hinges with a good thick grease. I use a type of gel lube that comes in a spray can. Also lube your trunk and hood hinges.
Not much to lube underneath. Maybe a small squirt of lube at the parking brake cables where they slide in and out of bushings.
