Toy twuck with a hiccupp
t rev
05-17-2005, 12:02 PM
I just bought an 85 Yota on gas and propane and it misses or farts on hills/acceleraion intermittently. It sounds like a carb backfire. All speed is lost and then you have to slowly start again and the problem doesn't appear again until the next hill or heavy acceleration.
Any help would be appreciated? :dunno:
KimMG
05-19-2005, 02:08 PM
check timing
vacuum routing
valve clearance
inspect spark plugs
air filter
cap and rotor
spark plug wires
air intake
t rev
05-20-2005, 12:46 AM
check timing
vacuum routing
valve clearance
inspect spark plugs
air filter
cap and rotor
spark plug wires
air intake
Thanks, i'll have to start that checklist with the spark plugs.
Someone suggested that propane requires a different gap than gas, so i'll have to do that. the wires are almost new.
corbinwaterski
05-24-2005, 09:24 AM
If your propane conversion was done correctly? it should not require any modification when switching over from propane to gas and vice versa. I'm not suggesting that you not check the above mentioned items, just my 2 cents...
t rev
05-28-2005, 01:25 AM
that part seems to work well
hasnt hiccupped for a while now
who knows maybe just bugs working out of it, the old guy I bought it off of barely drove it :screwy:
