before i installmellowboy 04-12-2002, 09:40 AM What hoses do i need? Like the radiator hose and shit like that. I know i'm gonna replace the timing belt and water pump. The wiring seems easy but the hoses is what bothering me. I just need new hoses. If someone can provide me with part number that'll be great. Thanks. Fishcat37 04-12-2002, 10:47 AM upper radiator hose - 95 del sol VTEC lower radiator hose - 90 crx si or probably 95 del sol VTEC im pretty sure that that's all of the hoses that i needed.....i would STRONGLY RECOMMEND HOWEVER TO REPLACE EVERY SINGLE RADIATOR HOSE ON THAT ENGINE. i didn't and i have had to replace almost every single hose because they've sprung leaks. almost every hose can be sourced off of a 95 del sol VTEC. (DOHC not SOHC...that's the si.) mellowboy 04-12-2002, 12:20 PM Originally posted by Fishcat37 upper radiator hose - 95 del sol VTEC lower radiator hose - 90 crx si or probably 95 del sol VTEC im pretty sure that that's all of the hoses that i needed.....i would STRONGLY RECOMMEND HOWEVER TO REPLACE EVERY SINGLE RADIATOR HOSE ON THAT ENGINE. i didn't and i have had to replace almost every single hose because they've sprung leaks. almost every hose can be sourced off of a 95 del sol VTEC. (DOHC not SOHC...that's the si.) Well is that all the 2 hoses that i need? OF course i'm gonna replace them cause i cut them off already. I just went out to buy the water pump, timing belt and distibutor cap. I think i got the wrong dist. cap. I asked for the del sol dohc one and they gave it to me. Well i'm gonna go check it out to see if its rite or not. thanks mellowboy 04-12-2002, 12:32 PM Ok i just found out that the distributor cap doesn't go with my b16. Its totally different. I have to go back to Napa and return it. Does the ' 99 - '00 SI one works? Thanks. ricodemus 04-12-2002, 12:42 PM from www.hasport.com Upper radiator hose : 92-93 Integra GSR, Acura part number 19501-PR3-000. Trim to fit. Lower radiator hose 90-91 Integra, Acura p/n # 19502-PR4-A00. Trim to fit. Distributor cap 90 Integra I followed this list closely, the swap goes on this weekend, I'll let you know the results mellowboy 04-12-2002, 12:48 PM Originally posted by ricodemus from www.hasport.com Upper radiator hose : 92-93 Integra GSR, Acura part number 19501-PR3-000. Trim to fit. Lower radiator hose 90-91 Integra, Acura p/n # 19502-PR4-A00. Trim to fit. Distributor cap 90 Integra I followed this list closely, the swap goes on this weekend, I'll let you know the results Oh alrite man thanks alot yo!:) 91zc 04-12-2002, 01:03 PM Originally posted by ricodemus from www.hasport.com Upper radiator hose : 92-93 Integra GSR, Acura part number 19501-PR3-000. Trim to fit. Lower radiator hose 90-91 Integra, Acura p/n # 19502-PR4-A00. Trim to fit. Distributor cap 90 Integra I followed this list closely, the swap goes on this weekend, I'll let you know the results This list is correct except that I found that the 92-93 GSR radiator hose was too short. So I got an extra lower hose and cut it to fit since it had approx. the same bend to it on the one part as the gsr hose. It worked perfectly.:) mellowboy 04-12-2002, 01:16 PM Originally posted by 91zc This list is correct except that I found that the 92-93 GSR radiator hose was too short. So I got an extra lower hose and cut it to fit since it had approx. the same bend to it on the one part as the gsr hose. It worked perfectly.:) So i get 2 lower hoses or what? :confused: ricodemus 04-12-2002, 01:38 PM Originally posted by 91zc This list is correct except that I found that the 92-93 GSR radiator hose was too short. So I got an extra lower hose and cut it to fit since it had approx. the same bend to it on the one part as the gsr hose. It worked perfectly.:) yeah, do you mean another gsr hose? or you sourced from a different car that looked similar? I just read on there that I need the damn teg rear mount bracket. I hope my motor has that shit on it, since it was supposed to come with mounts. damn... mellowboy 04-12-2002, 04:15 PM I wonder if i need that rear integra mount bracket?? I have HCP and it came with 4 mounts so i'm not sure if i need it or not? Do i? Phatwhippin_CRX 04-12-2002, 05:37 PM between my site and the hasport site, the swap should be a snap! Phatwhippin_CRX 04-12-2002, 05:39 PM about the mounts...... first off, you cant use stock mounts. Secondly, no matter what kit you use, you still need the rear bracket from a 90-93 teg..... c'mon guys this stuff is cake! Just gotta look around..... ricodemus 04-13-2002, 10:07 AM hah, shoulda known Phatwippin would say something about the rear mount (after reading the webpage). I was happy to see that I did get the rear mount for the SiR, otherwise I woulda been screwed because the closest teg mount was in Georgia. Of course I got the billet HASport mounts! The old motor is out, starting on the b16! later mellowboy 04-13-2002, 09:29 PM Originally posted by ricodemus hah, shoulda known Phatwippin would say something about the rear mount (after reading the webpage). I was happy to see that I did get the rear mount for the SiR, otherwise I woulda been screwed because the closest teg mount was in Georgia. Of course I got the billet HASport mounts! The old motor is out, starting on the b16! later you wanna see who can get done first?;) ricodemus 04-14-2002, 01:07 PM well, I'm not really doing it, I'm kinda watching and learning. but we'll see who gets done first.... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
