93 6.5 diesel
Google
Web AF
drof
05-15-2005, 05:33 PM
My revcounter and speedometer jump around together even while the motor isn't running. All I need to do is turn the key. Has anyone come over this problem out thier?
Pamsdad
06-03-2005, 09:38 PM
Bad Grounds are a Common Problem...
troy1
06-03-2005, 10:02 PM
bad ignition switch? 95 have this happen but the tech and speedo quit working and cause bad shifting
troy1
bad ignition switch? 95 have this happen but the tach and speedo quit working and cause bad shifting
drof
06-05-2005, 01:40 PM
Thanks for the replies.
I have already tried running a ground wire directly to the back of the instrument cluster and cleaning the connectors which made no difference.
The ignition switch has been giving some problems. Starting and on a dark night I can see arcing in the column starter switch. Sounds like the two problem could be the same thing, I think Ill try replacing the switch next.
thanks again Drof.
Google
Web AF
