94 454 Too much gas & lost OD & lock up
Google
Web AF
4x4kritter
05-14-2005, 01:40 PM
94 C 3500 454 stumbled and died at a stop sign... smelled gas real bad... wouldn't fire back up. I rolled down a hill, out of the road. No leaks... injectors are spraying too much. Held it to the floor and finally started and smoked like crazy. Will die before it gets down to an idle. Driving it home... not allowing it to idle, I find there is no converter lock up or overdrive... both of which were fine before it quit on me. This has all happened in about 45 minutes. I'm trouble shoot'n online and in the manual. Oh, get this, no engine light at all !!!!! Thanks in advance for any input. I did a word search in this forum and read every post that came up but nothing quite like this is out there. Thanks again... Kritter
Snowgoer05
08-15-2005, 07:20 PM
Hi i was wondering wich tranny you had ive seen this problem ina 350 work van not the tranny problem but the injector problem i ended up changing the comp but this could be a much smaller problem i would have to know what the tranny is before i could tell you anymore
abldo96
10-05-2005, 07:40 AM
Did you find the answer to your problem? I have the same symptoms in a 94 Winnebago Motorhome, and need the same info.
Thanks, SRD
Google
Web AF
