95 jimmy/HVAC problem
Google
Web AF
metallica21156
05-13-2005, 08:21 AM
I have a friend of mine whose jimmy is having lots of problems. the CPI is shot and i think the EGR needs to be cleaned. Any way the major problem he wants to deal with now is that the AC and heat doesn't work. i checked the fuse ands all's good there. he said that sometimes it will come on and then it will just shut off. if you turn the switch it sounds like you can here the vacum working. is there any way to test the fan speed switch?
Rick Norwood
05-13-2005, 09:23 AM
It almost sounds like the freon is too low. There is a low pressure switch somewhere in the system usually on the accumulator (big silver canister), which is normally by the passenger's side fender wall in the engine compartment. It might also be a bad connector to this same switch or a bad switch itself. My daughter's 95 Chev Pick-up 4.3L just had the same problem last week. We ended up replacing the actual low pressure switch itself. One way to test it is to GENTLY wiggle the Harness/Connector right at the switch and see if it kicks on or stays on. The other thing that I learned was that this switch can be removed without loosing all of the freon in the system, as it has the tire valve type (Schrader valve?) valve under the switch.
When it does run, is the air cold?
metallica21156
05-13-2005, 04:41 PM
i kinda knew about the ac not working. the problem is the fan doesn't even run either postion. heat or cold. it will run and you shut the truck off and later turn the truck back on and it doesn't work.
Rick Norwood
05-13-2005, 04:48 PM
I have had those blower fans crap out on me before. Unplug the fan at the connector and run a hot jumper wire straight from the battery to the connector to see if the fan itself works. I'm not sure how the fan assembly is grounded but check to see if the ground is good. If all checks out good I'd look at the switch.
BlazerLT
05-14-2005, 01:25 PM
Will the fan run in the high position.
If it only runs in high, the resistor pack is shot.
If not, the switch is bad or the blower motor is shot.
metallica21156
05-15-2005, 09:25 AM
see thats the thing. you leave it all turned on and its running. turn the key off and turn it back on and it doesn't work. keep in mind that i didn't touch the controls. just turning the key of and back on stoped it. fuse is also good.
BlazerLT
05-15-2005, 01:20 PM
You didn't answer my question.........
metallica21156
05-15-2005, 03:30 PM
it will work in all the settings(when its working), AC,Heat,Hi, Lo, the ac doesn't work because of a low charge.
BlazerLT
05-15-2005, 03:38 PM
I am talking about the FAN, not the CONTROLS.
Your first post states your FAN doesn't work properly.
biv343
05-15-2005, 04:49 PM
Had the same issue with my Bravada, and it was the blower motor itself, not the resistor pack or the controls. It would do the same thing - work until you shut the vehicle off, start it back up and the blower wouldn't come back on until it was damn good and ready. $65 for a blower motor fixed my issue.
metallica21156
05-15-2005, 09:26 PM
any way to check if the blowers the problem. like i said before the fan when its working it will work like it should. ALL SPEEDS.
BlazerLT
05-15-2005, 09:35 PM
It is the switch or the blower motor itself.
Blower motor more than likely.
metallica21156
05-18-2005, 09:05 PM
if you hit where the blower is it will work. i think its the blower motor or a wire to it.
Cadillakin'98
05-18-2005, 09:53 PM
Sorry to be such a smart ass, but what makes you think that?
HERE'S YOUR SIGN
ZL1power69
08-02-2005, 10:45 PM
HERE'S YOUR SIGN
because its my truck he's talking about. fan runs in any position>turn key off and then back on again a sec later>fan doesn't run. BUT if if you pop the hood a hit the fan housing it clicks back on. there is a bad ground on the fan side of the connector.
Google
Web AF
