95 Blazer - How to replace antilock brake sensor???
Google
Web AF
Chandler327
05-11-2005, 05:31 PM
Does anybody know how to replace an antilock brake sensor? I found where the harness is to disconnect the sensor but i am not exactly sure how you remove the sensor from the hub it self. Thanks for any advice!!!
BlazerLT
05-14-2005, 02:02 PM
Why are you replacing it?
that1guy
07-24-2005, 04:27 PM
That sensor is not mounted to the hub at all and is not that hard to replace. You still have to take the hub off to get the sensor off though. That sensor is actually mounted to the backing plate for the rotor. You got two ways to get it off. You can either drill out the rivits that hold the sensor on that backing plate. Or you can take the hub off. Once you take the hub off, that backing plate comes right off with the sensor attached to it.
Google
Web AF
