Keyless Remote for '01 Rodeo
Google
Web AF
Tespin
05-11-2005, 03:02 PM
1. Can I buy a Keyless Remote off of E-bay and make it work on my truck?
2. Where is the best place to buy a Keyless Remote?
3. Is there anything in particular I should be looking for?
My Truck:
2001 Isuzu Rodeo LS
V6 3.2L
115k Miles
Thanks!
amigo-2k
05-11-2005, 03:28 PM
ebay
ebay
ebay
seems to be the cheapest place to pick one up, and I haven't heard any bad things about them.
Onblsht
05-19-2005, 09:23 AM
'98 - '02 Isuzu Rodeo and Trooper (with factory keyless entry)
Instructions for programming
1. Get in car and make sure all doors are unlocked.
2. Open driver's door and leave open.
3. Put key in ignition.
4. Turn key to 'on position' (dash lights on, but do not start) and back to 'off position' 3 times in 5 seconds or less. (you must turn the key very fast)
5. Close and open driver's door 2 times in 5 seconds or less.
6. Turn key to 'on position' and back to 'off position' 5 times in 5 seconds or less. (turn key very fast)
7. Close and open driver's door the doors should lock and unlock twice after this happens push the lock or unlock button on the remote, doors will lock and unlock. Push the lock or unlock button a second time and doors will lock and unlock again. You are finished!
The above sequence erases all previous codes and adds the new code as #1. If you are adding a second remote, you should follow the same sequence with the exception of step 6; instead of turning the key to the 'on position' and back to the 'off position' 5 times in 5 seconds or less, do it 3 times in 5 seconds or less and then continue to step 7.
***Remember to turn the key to the on and off position very fast.
Google
Web AF
