Spare Tire Rack Adjustment
Google
Web AF
kenc195
05-11-2005, 01:46 PM
1997 spare tire is slamming around on every bump. It latches once not twice as posted elsewhere. I can't see any adjustments but I am sure it has some in there someplace. Any experiance strenght or hope?
Ramblin Fever
05-11-2005, 08:17 PM
Spray WD-40 on the latch as well as the release, then try it. The trick is to not "slam" it, but to give it a good push, but move with it - if that makes sense.
kenc195
05-14-2005, 02:14 PM
The WD-40 worked pretty good but I found I still had to slam it a little harder then I felt comfortable doing. This morning I unbolted the latch mechanism and place 4 flat washers (1 at each bolt) between the mount and the latch. That moved the latch about 1/16" closer and seemed to work for now. It may still bounce over the most severe bumbs but at least speed bumbs at the shopping center arn't causing it to slam.
Google
Web AF
