Keyless entry programming for a '99 Tahoe
Google
Web AF
ohmeohmy
05-11-2005, 01:09 PM
I need to know how to program a Keyless entry remote for a 4WD Tahoe date 03/99. Can anyone help me? also the Tahoe came without any remotes, but it does have keyless entry on the original sticker, so it was/is equipped with it. So I have two questions 1) can someone remove the keyless entry equipment? and 2) the part number for this VIN shows a remote for the '97 Blazer would a '97 Jimmy remote work? it has the same FCC # but not the same Part #. Any help would be GREATLY appreciated!
Onblsht
05-19-2005, 09:25 AM
Your remote number is FCC: KOBUT1BT / GM: 15732803 for the 99 Tahoe.
Transmitter Programming Base Model:
If they key is in the ON position during the programming procedure, the horn chirp will be disabled, if the key is in the OFF position, the horn chirp will be enabled. The horn will chirp when the lock button is pressed two times.
When reprogramming the remote control door lock reciever, All transmitters must be programmed at this time in order for the transmitters to operate the vehicle. Transmitters not programed at this time will not work and the procedure will have to be redone with all the transmitters.
1. Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
2. Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
3. Repeat step 2 for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
4. Remove the ground applied to the DLC.
5. Lock and unlock the doors in order to verify the transmitter operation.
6. Activate the rear window release in order to verify the transmitter operation.
Method for Higher End models:
Have each of the transmitters that you intend to program ready. This vehicle will allow you to program a maximum of four transmitters programmed at one time.
Turn the ignition to the RUN position, then back to the OFF position. This will disarm the theft-deterrent system.
Remove the RADIO fuse (Fuse 17).
Turn the ignition from the OFF position to the RUN position three times quickly, within five seconds. The vehicle will respond by locking the doors, unlocking the driver's doors and releasing the tailgate or panel doors. The transmitter is now ready to match to the vehicle.
Press and hold the LOCK (1) and UNLOCK (2) buttons on the first transmitter for 15 seconds. The vehicle will respond as in step 3.
Repeat step 4 for the remaining transmitters.
Replace the RADIO fuse.
Check that all transmitters work by pressing their buttons.
Google
Web AF
