Water pump replacement.. and upper brake light/bar/LED replacement
Google
Web AF
vballfun
05-10-2005, 03:05 PM
Just two quick questions for anyone who's done either of these before.
How difficult is a waterpump replacement on a 95 blazer (4.3L) (would this job be comparable to a starter replacement.. or easier since less spatial manuevering problems.
also.. my taillight strip of LED on my rear hatch is no longer lighting and that will fail my inspection... but I don't see 'how' it comes off the window... it looks like it is an integral part to the glass 'component'. Has anyone replaced this before?
any info would be helpful,
Thanks. :confused:
Tim
EmTea
05-10-2005, 05:26 PM
In my experiance there are two screws that hold the bar down.
Remove those and it comes off.
The LED bar its self slides out.
But thats a 99 Blazer.
vballfun
05-11-2005, 01:07 PM
Yep.. I can't believe I missed that.. thanks. I must have puzzled over that for about 20 minutes the other day.. I even practically climbed on the hood to look at it. Went out and found the screws right away after reading your post.
Thanks,
Tim
xtrememeasures10
05-11-2005, 10:04 PM
If you know how to sodder and use a multimeter with a diode tester. youll save alot of money. Those are not cheap. well they werent for my caddy. so im assuming the same for yours.
vballfun
05-12-2005, 09:49 AM
Yes Local Dealership parts dept wants $103.37 for one..
I'm pretty sure it still works.. I can wiggle the wire connection to it with the hatch open and the brake pedal depressed and it comes on fine.. the problem is that the wire is under a lot of tension and may have been damaged.. so if I can just remove the bar and run some tests I can probably just snip the wire and solder and electrical tape a new segment of wire on to it to give it more 'play'
I replaced my rear window lifts and they have 'shoved' my rear window up about an inch.. which has put the tension on the wire.. (and also now lets a little bit of air in when on the highway)
Google
Web AF
