Codes 303 and 430 on '97, how do I fix it?
Shoemake
05-10-2005, 02:52 PM
"Service Engine Soon" light appeared last week. I finally broke-down and bought an inexpensive code reader. (1997 Taurus G) Codes 303 and 430 were present.
I understand the first is a cylinder 3 misfire and the other is a low O2 detection on bank 2. I've done a little research, and 303 probably caused 430.
I need some possible solutions to fix this problem. Could this only be a clogged injector or a bad/fouled spark plug?
Thanks in advance.
sfontain
05-10-2005, 03:05 PM
Thanks in advance.
Yes, those causes are plausible. If it's been a while since you've had a tune up then you might want to install new plugs (Motorcraft or Autolite) and wires (don't be cheap with the wires either).
Barring the plug/wire/injector, your ignition module may be going bad.
