Ignition headache
ImportKiller
05-10-2005, 01:34 PM
I have a 1989 trans-am GTA, with a HEI ignition with an external coil. My problem is the magnetic pickup in the distributor keeps rusting on me. I heard of drilling a hole to rellieve moisture, is that true? And where do I drill the hole and hole size. Or is there another reason for the rusting??
volkerc
05-11-2005, 06:14 AM
never heard of that before. what do you mean by rust? a light film is normal as the pickup is not treated, just bare metal. so it is anormal thing, unless you are talking about that it is falling apart
99firebird
05-11-2005, 11:12 PM
You should be able to use some di-electric compound inside the distributor to prevent rust and carbon buildup. This stuff prevents some arcing. A very light coating on the contact areas inside the distributor may help you out. Stuff looks like vaseline.
