Hand Pump
Google
Web AF
kd3yt
05-07-2005, 05:20 PM
Question for all,
If you use a hand pump to fill differentals and transfer case,
what do you clean the hand pump with after use?
Would not want to contaminate anything when I use it for the next time!
BlazerLT
05-07-2005, 10:10 PM
I would just let it drain out really.
Maybe some paint thinner to clean it and let it dry out completely.
rlith
05-08-2005, 09:00 AM
Use brake clean. Thinner or mineral spirits will kill the plastic...
blazee
05-08-2005, 11:23 AM
I usually don't worry about it. Before I pump any fluid in, I always have to pump the old fluid out. Pumping the old out first removes any different kind of fluid that may be remaining inside the pump.
rbuck
05-08-2005, 12:19 PM
I Have a small tank The name is "sure shot" it is a pressurized Tank holds about two quarts @ 60 psi work like a charm. you can find them at lowes
Google
Web AF
