94 Wagon - Reverse lights and Oil pressurew98seeng 05-07-2005, 04:51 PM My wagons reverse lights don't work. I have checked the bulbs (OK) and fuses (OK). I need to know where the reverse switch is so I can check it out. I have looked under the floor console and found nothing so i presume it's on the tranny, but don't know which one is the switch. My other problem is the oil pressure light comes on when I am idleing when the car is warm. It never happens unless I am ideling and the rpms are low. Where is the oil pressure sending unit on the engine? How difficult is it to replace the oil pump (in case this turns out to be the problem)? Thanks for the help. Ian S. w98seeng 05-09-2005, 07:39 AM I can't believe that with all the knowledge on this board, no one knows the answer to these two questions. :disappoin way2old 05-09-2005, 10:24 AM On the back up lights,I am not really sure on the 94, but it is either in a switch that attaches under the linkage, or there is a small round plug on the transaxle that screws out. The oil pressure switch should be close to the oil filter area. Either a 2 wire or onw wire switch. Hope it helps some. Did not see your post earlier. I got a 90 acre farm that has no internet access that I goto on weekends. Sorry. TomV 05-09-2005, 01:10 PM Before you address mechanical issues, do you have enough oil in the system? w98seeng 05-10-2005, 11:15 AM On the back up lights,I am not really sure on the 94, but it is either in a switch that attaches under the linkage, or there is a small round plug on the transaxle that screws out. The oil pressure switch should be close to the oil filter area. Either a 2 wire or onw wire switch. Hope it helps some. Did not see your post earlier. I got a 90 acre farm that has no internet access that I goto on weekends. Sorry. Hey, no problem. Many thanks for the info. Before you address mechanical issues, do you have enough oil in the system? This was the first thing I checked and it's right up. The car leaks no oil, actually, it doesn't leak anything. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
