4x4 doesn't work chevy99
Google
Web AF
reg!
05-05-2005, 10:37 PM
Hi ! i have the push button system and when i use it to shift to 4hi or 4 low or 2hi the push button light is ok when i select one of them , the front wheel doesn't do the right thing ,with a scan it say when u are in 2hi the front diff, is engage and when u are in 4hi or 4 lo the front diff. say not engage, but when i put to auto track the scan say engage for the front diff. , and when you use the push button to switch, some time the transfer case stop to neutral, the 4x4 doesn't work and i dont know if the encoder or the 4x4 module is the problem but it seem to be possible and it cost many $$$ 1300 can.
What do u think about this no code failed?? (my usual lang is french dont care about it!) thanks ! ps:i change the push button switch but dont solve the problem... :shakehead
gremlin96
05-08-2005, 03:48 PM
http://www.automotiveforums.com/vbulletin/showthread.php?t=392608
try cleaning the connectors first. see if that helps. also check out the above thread. seems that the switches are not lasting a long time and need to be replaced.
l'essai nettoyant les connecteurs voient d'abord si ce les aides vérifient également le fil ci-dessus semble que les commutateurs ne durent pas un long temps et n'ont pas besoin d'être remplacés
http://babel.altavista.com/translate
reg!
05-10-2005, 05:39 PM
tank you gremlin96, i have 2 switch and i test those 2switch and it's supposed thats not the prob. , my mechanical man say it's the ATC module who controle the encoder ( the small electromagnet fix to the transfercase) this ATC is back order for 7 days, if this solve the bug i will send you a come back... A+
Google
Web AF
