Oxygen Sensors- part numbers and replacement?Absolut Talent 05-05-2005, 12:03 AM On a 1996 blazer, I should have 4 oxygen sensors correct? Two should be in front near engine, two should be underneath? Where exactly would I find these, both in front and underneath? And can anyone recommend a replacement that I could order online? Ive seen several different types, but I dont want to order 4 of the wrong ones when they are $50 a piece. Anything special I also have to do for replacing them? Or are they just a yank and replace (like sparkplugs) type deal? BlazerLT 05-05-2005, 03:55 AM One on each exhaust manifold, one before the cat and one after. Are you going to be going with Bosch or AC Delco? Just FYI, bosch make AC Delco's O2 sensors and they actually designed the system, so if Bosch are cheaper, go for it. Visit here for Bosch part info: http://www.boschusa.com/AutoParts/PartFinder/partfinder.asp Visit here to find the right AC Delco Model numbers for your truck: http://www.acdelco.com/html/catalog/index_auto.htm rlith 05-05-2005, 06:21 AM Well, just remember, some have 3, some have 4... Absolut Talent 05-05-2005, 05:05 PM I wasnt sure which one I was going with, was asking for a suggestion of which is better (i figured ACdelco would be one choice, but didnt know if there was other quality alternates) And at ACdelco, it shows SENSOR,HTD OXY(POSN 1) OEM SENSOR IN EXHAUST MANIFOLD SENSOR,HTD OXY(POSN 2) OEM SENSOR FRT OF CONVERTER SENSOR,HTD OXY(POSN 3) OEM SENSOR POST CONVERTER Shows 2 req on the posn2, and 1 on pos 1 and 3. So that means I have one in my exhaust manifold, two in the front of the converter, and one after the converter? Is that right? Do I need anything else when chaning out the sensors? or just order the sensors and all will be fine? I am seeing 1-way female, 4-way female, 8way male connectors, dont need to order those? BlazerLT 05-05-2005, 06:07 PM Please read my previous post. Absolut Talent 05-05-2005, 06:19 PM ok, i mustve just passed over that part, sorry. and I will ask once more before placing my orders, but do I need any of those connectors? Or anything else special when doing this? Just want to make sure I have all that is neccessary for when I do this BlazerLT 05-05-2005, 06:29 PM ok, i mustve just passed over that part, sorry. and I will ask once more before placing my orders, but do I need any of those connectors? Or anything else special when doing this? Just want to make sure I have all that is neccessary for when I do this Just go to your local autoparts store and get the bosch ones. They are cheaper and are the same thing. blazee 05-06-2005, 11:53 AM Bosch is having a special right now, they will give you a $10 gas card for buying an oxygen sensor. Just print out the form and mail it in. http://www.boschusa.com/images/promotions/O2Sensor10GasCard_Tear.pdf To get a $10 gas card for each one..buy them seperate, so you get a receipt for each one. Print and mail in a form for each one. They let you have up to 4 per household, but you have to send them all in seperate. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
