Fuel filter on '99 Malibu, rusted fuel lines :(
Malibullsh*t
05-04-2005, 05:43 PM
I am attempting to change the fuel filter on my '99 Malibu myself because the mechanic I took it to said my fuel lines were rusted pretty badly and he didnt want to touch it.. I have sprayed it with penetrating oil about 5 times over the past 2 weeks... Anyone have any good advice on how to get it off without breaking the lines?
bcopeland
05-08-2005, 04:07 PM
You should be alright. I think it takes a 5/8 and a 9/16 or a 1/2 but it might also take a 12 mm. You should not have much of a problem. But if you live ip north with salt etc., you should wash the underside of the car after winter every year.
mcquadey
05-13-2005, 06:25 PM
if the line doesn't seem to break lose, hold the line in place and turn the fuel filter. this will only work if one side is a quick disconnect fitting. If both sides have the threaded fitting, and you can get one side undone, then u can also turn the filter and hold the line still. and whatever you do, don't heat up the lines! lol
