Clearance Light OEM kits
Google
Web AF
AndyC
05-04-2005, 04:32 PM
Hi Everybody...
I'm looking for a source (as well as part numbers) for the three piece clearance lights as found on the 2005 Silverado (2500). I have found a source for the clear plastic style (aftermarket), but I'm looking for the amber OEM style...
Thanks!
Andy
Chevyman15004X4
05-04-2005, 06:12 PM
Well, There is a place in Lenexa, kansas called LMC TRUCK that has exactly what you are looking for. I was just fixing to order a 5 pice clearence light set with a 5 light tailgat set and then 5 lights for the running boards on each side. The 3 pice set you are probably talking about cost $55. The part number is 38-1071. LMC Trucks phone number is 1-800-562-8782. It is the 3 pice light you see on all of the newer chevy trucks. 2 small outside lights and a long middle light. The kit comes with a wire harness, quick splice connectors (I would rather solder and heat shrink them personally) and a dash mount panel toggle switch. The web site for LMC is WWW.LMCTRUCK.COM They have catalogs with all the parts for a spacific vehicle pluse a few acceries.
AndyC
05-05-2005, 03:10 PM
Chevyman...
Thanks for the info... Turns out to be just what I was looking for!!!!
Thanks for your help.
Andy
Google
Web AF
