305 heads on 350 block what size intake?
Google
Web AF
dmbrisket 51
05-03-2005, 04:56 PM
i beleve the intake itselfe is the same size for all sbc, but should i use 350 injectors or 305 injectors? 58cc cumbustion chamer.
BlenderWizard
05-03-2005, 05:54 PM
Having just gotten out of my honda, I know that one of the performance upgrades was getting bigger fuel injectors for the car. So, applying that to this situation, I would go with the bigger injectors.
dmbrisket 51
05-03-2005, 06:06 PM
ok, im just kinda worried that the large injectors will be to much fuel maken me burn lean, std 305 heads are 64 cc, these are smaller then that, see my concern?
jeverett
05-04-2005, 07:50 AM
Wouldnt too much fuel make you burn rich?
dmbrisket 51
05-04-2005, 08:09 AM
whops yes, rich, sorry thought one thing typed another, and after thinking abou it last night, the moter is going to "take in" as much air as a 350 would, so it should get as much fuel as a 350, its just going to compress it in a very small space
jeverett
05-04-2005, 09:15 AM
And the compression ratio would therefore be raised corroect? So you'd have to run a higher octane gas to prevent detonation.. OR retard the timing a bit
BlenderWizard
05-04-2005, 10:01 AM
Hehe... retarded timing...
dmbrisket 51
05-04-2005, 10:33 AM
lol, ill probibly do a little of both, i dont want to run 92, im hopeing to be able to run 89 with timeing set back a degree or two
Google
Web AF
