Outside Door Handle
Google
Web AF
mchristo63
05-03-2005, 08:01 AM
Has anyone had a sticky outside door handle, '99 Silverado. When you open the door the handle stays out. I have to manually push the handle back to home position so the dome light won't stay on. Before I take off the door panel and look what's going on, has anyone repaired this problem? If so, do I just need to get a new handle assembly or is a simple fix (lube, spring)?
Thanks
BlenderWizard
05-03-2005, 08:56 AM
the one on my passenger's side was doing that, I was thinking about squirting some wd40 or liquid wrench in there
kenny-1907
05-03-2005, 09:05 AM
I would try what BlenderWizard suggested. At least that is what i would try first before tearing the door apart anyhow. Some people might say to not use WD-40 because it will attracxt more dirt afterwards so might i suggest some graphite or some other lube that will not attract dust to it. I have seen a guy once use powdered graphite and mix it with some rubbing alcohol so that you could spray it and it would get into all the little nooks and crannies then the alcohol would evaporate leaving just the graphite behind. Just a thought.
Faze3
05-03-2005, 09:13 AM
Graphite powder is another suggestion. Supposedly better than WD40 or silicon.
mchristo63
05-03-2005, 12:16 PM
Thanks for the suggestions.
jethro_3
05-03-2005, 03:07 PM
The door removal takes 15 minutes tops. Why not find out what is rubing?
mchristo63
05-03-2005, 03:38 PM
Yeah, I have had it off before to replace a regulator last year. Best I look before just spraying crap into the door handle.
silveradoking
05-03-2005, 06:35 PM
The spray won't work.....You have to buy a new handle....30-40 bucks....
mchristo63
05-04-2005, 07:47 AM
Is that just a handle or is it an assembly?
silveradoking
05-04-2005, 04:51 PM
the whole assembly....very easy to change....
Google
Web AF
