Clicking when I turn the wheel.
Google
Web AF
evansdad
04-29-2005, 09:22 PM
I have a 00 Cavy, when I turn the steering wheel to the left or right there is a clicking in the steering. Kinda like something is binding. I have checked the tie rods they are fine. Dont think its in the front end but does anyone know what this may be? How do I fix it?
PsychoJJ
04-29-2005, 11:21 PM
Meh, I have an 04 and it does the same thing. I dont think its that big of a problem I actually think its just normal. Unless you have aftermarket suspension then it could be a problem. To date though I have yet to hear a good thing about stock cavalier suspension.
mrmilbro
04-30-2005, 10:57 AM
its your CV Axels that happened to mine i got it fixed
mAxxx
04-30-2005, 02:17 PM
i have a 96 and it does the same thing, as my friend's 99 so its no big deal i guess :D
Ryan066
04-30-2005, 02:30 PM
no big deal when your axle flops off and your SOL..
its your CV joints... check the boots to see if they are split or cracked open.
if it doesn't do it straight ahead then it's not your wheel bearings.
first make everything is tight and check the bushings.
Tookie
04-30-2005, 05:46 PM
Agreed. It's the CVs. Usually a first sign that some directly related component is ready for a good checkup. The only other time I've heard this happen to no fault is when the mech used a type of pull-tag/boot bank that engaged the turning wheel and made a clicking sound during turning only.
Tookie
evansdad
04-30-2005, 06:26 PM
Ok but if a cv joint is bad wouldnt i get a vibration at high speed. I really doubt its the axles but ill look into it just incase but it feels like its in the column itself. Oh yeah and its stock suspension
cousincletus
05-01-2005, 05:30 PM
I don't think it's the CV joints either. Try greasing the steering column intermediate shaft (the telescoping part). If it is making a rhythmic click, click, click when turning at slow speeds then I would say it's CV joints.
ebritt
05-06-2005, 08:41 AM
Does it click when the car is sitting still? If so it could be the column or maybe a bad rack & pinion, if not I'd guess the outer cv joints. Outer cv joints usually wont cause vibration while driving unless they're about to explode, inner cv joint will cause vibration especially when slowing down but wont click but clunk.
Hope that helps :lol2:
evansdad
05-06-2005, 10:08 PM
Yeah it does the noise when standing still and when slow speeds like turning a corner. Well its not really a clicking now that i think about it, its more like a pop.
Ryan066
05-07-2005, 12:05 AM
does it make the noise when steerinf the wheel back and forth?
if it does just hold the outter tie-rod and turn the wheel if u can hear or feel any play then shes bad... then try it with the car running if it doesnt do it with it running then it should be fine.
cousincletus
05-07-2005, 08:28 AM
GM had a TSB about the intermediate shaft popping. If all else checks out, that's probably what it is.
Google
Web AF
