Acceleration problemTA6.6 04-28-2005, 10:21 PM I have a 1999 3.8L in excellent condition except this problem of acceleration. You get a slow pick-up during acceleraton. I did a tune-up replacing spark plugs, wires and transmission service. I read about this oxygen sensor, but no diagnostic warning. I only have this car 6 months @ 70,000 miles. Any ideas, please advise......... wrightz28 04-29-2005, 09:46 AM I have a 1999 3.8L in excellent condition except this problem of acceleration. You get a slow pick-up during acceleraton. I did a tune-up replacing spark plugs, wires and transmission service. I read about this oxygen sensor, but no diagnostic warning. I only have this car 6 months @ 70,000 miles. Any ideas, please advise......... Can you elaborate a little more as to what's happening? Sounds, smells, shaking, coughing, sputtering? At this point we could throw a laundry list of possible scinerios. On your year, if an O2 is bad enough to cause a performance issue, it should throw the MIL light. If nothing else seems out of the ordinary I would first suspect either a fuel pressure issue or clogged exhaust. But, if you could give some more insight, no matter how insugnificant it may seem, it could be a key to diagnosis. TA6.6 04-30-2005, 03:03 AM Can you elaborate a little more as to what's happening? Sounds, smells, shaking, coughing, sputtering? At this point we could throw a laundry list of possible scinerios. On your year, if an O2 is bad enough to cause a performance issue, it should throw the MIL light. If nothing else seems out of the ordinary I would first suspect either a fuel pressure issue or clogged exhaust. But, if you could give some more insight, no matter how insugnificant it may seem, it could be a key to diagnosis. The engine sounds noisy with little vibration on steering, like engine under stress. I did have unusual smell few occasions. Some more info, I had the fuel filter replaced and fuel injectors cleaned during the service. Could this help. Thanks wrightz28 05-02-2005, 10:12 AM Eh hah! Smell, and sound. Ratlling cound like a tin coffee can full of marbles and a cookded egg smell? Catalytic converter plugged. Similar sound and sweet oder? water pump failure. However I would suspect the first case with the cat. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
