Strokes at idle and slow speeds
View Full Version : Strokes at idle and slow speeds Strokes at idle and slow speeds Drthru 04-27-2005, 07:42 PM OffroadX 04-27-2005, 09:29 PM What are strokes? A knock sensor problem will not trigger the check-engine light on its own, and will not cause any problems. RAREROD74 10-24-2005, 12:51 AM correct the knock sensor will not cause the check engine light to come on but, if the dealer didnt reset base idle with the consult due to the the change of igntion timing when the head gaskets were chaged than the ecu see conflicts due to the iac solenoid uses ign timing as a reference and the tps postiion to allow air flow at closed throttle . setting base idle should fix the problem Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
