turn signals not working
Google
Web AF
IGOEZONU
04-26-2005, 07:04 PM
My 92 grand prix gtp turn signals arn't working. Hazzards work fine. I see on the board that someone else had this problem. Is this common on these cars? Is it the turn switch on the steering colum?
jc83
04-30-2005, 12:31 AM
my 95 grand prix se gave out last summer..did the same as yours--hazards work but no turn etc.--anyhow it turned out to be the turn signal switch inside the steering column..the tabs that hold the unit in place are made of plastic and wear out...springs inside force upwards equals no contact means no electricity flow no turn signal..so being slightly smart i went to junkyard got another one after much hard work and it too had same issue!!!! me and cars are a battle from hell! you only find this out after assembly! so i pulled out a wire solder melter thingy and heated up the tangs melting/pushing plastic downwards to make unit contact once more..so good luck....brand new ones i believe cost big bucks look online at pontiac parts etc.
cockblocker
05-02-2005, 11:49 AM
I had the same problem with my '96. What I did was I removed the steering wheel and airbag coil (in pieces ;-)) Sprayed Contact Cleaner down onto every bit of copper I could see while working the level up and down. After about 8 or 9 minutes of that they worked perfectly and ever since...for the past 4 months.
You should be able to get some of that cleaner from a Lowes or Home Depot in the wiring section. And watch it because it is flammable but it evaporates VERY quickly.
IGOEZONU
05-03-2005, 04:09 PM
[thanks for the reply. I have taken the unit out and will check out your advice. thanks, a new turn signal switci is 265.00 canadian!!!
roc1150
05-05-2005, 09:11 PM
My 92 grand prix gtp turn signals arn't working. Hazzards work fine. I see on the board that someone else had this problem. Is this common on these cars? Is it the turn switch on the steering colum? I have a 94 grandprix gt mine did the same i replaced the flasher and also i don't know if you know but there is a recall on that.
Google
Web AF
