Power Steeringfrahman 04-26-2005, 11:42 AM Where is the power steering fluid container in the 2000 Jetta VR6 to put the fluid in? boschmann 04-26-2005, 12:49 PM If I remember correctly it's just behind the left headlights. CaseyVR6 04-26-2005, 01:19 PM It's on the left side, just about the middle of the engine compartment... should have a green cap with a plastic post sticking up from the middle. There is a slot in the post at the top to open the lid with a key or coin or screwdriver... Just keep in mind if you're losing fluid the rack is going bad. You might be able to pull 2 weeks out of the deal, probably closer to 6 or 7 days. Just a heads up. frahman 04-26-2005, 02:42 PM Thanks.....I just posted another inquiry. Please respond.... It's on the left side, just about the middle of the engine compartment... should have a green cap with a plastic post sticking up from the middle. There is a slot in the post at the top to open the lid with a key or coin or screwdriver... Just keep in mind if you're losing fluid the rack is going bad. You might be able to pull 2 weeks out of the deal, probably closer to 6 or 7 days. Just a heads up. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
